LPC2210 pdf datasheet (16/32-b
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-25
分享资料个
The LPC2210 is based on a 16/32 bit ARM7TDMI-S™ CPU with real-time emulation
and embedded trace support. For critical code size applications, the alternative 16-bit
Thumb Mode reduces code by more than 30% with minimal performance penalty.
With its 144 pin package, low power consumption, various 32-bit timers, 8-channel
10-bit ADC, PWM channels and up to 9 external interrupt pins this microcontroller is
particularly suitable for industrial control, medical systems, access control and
point-of-sale. LPC2210 provides up to 76 GPIO depending on bus configuration. With
a wide range of serial communications interfaces, it is also very well suited for
communication gateways, protocol converters and embedded soft modems as well
as many other general-purpose applications.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
