基于HV7361DB1脉冲产生器的参考设计
消耗积分:5 | 格式:pdf | 大小:197.36KB | 2021-01-13
李军
分享资料个
说明
  • HV7361DB1, Demo Board for the HV7361, three level +/-100V 2.5A pulser, with integral MOSFET driver, P&N channel output MOSFETs and a T/R switch. The demo board consists of four channels of high speed matched driver, four gate-coupling capacitors driving two pairs of high speed and high voltage complimentary P and N-MOSFETs in one 5x7mm, 22-lead LFGA package. This circuit is an ideal, size optimized, high voltage and high current RTZ ultrasound transmit pulser
主要特色
  • 信号类型
    脉冲
评论(0)
发评论
下载排行榜
