HA-2529 pdf datasheet (20MHz,
消耗积分:3 | 格式:rar | 大小:336 | 2009-01-07
分享资料个
The HA-2529 is a monolithic operational amplifier which
typifies excellence of design. With a design based on years of
experience coupled with the reliable dielectric isolation
process, this amplifier provides an outstanding combination of
DC and AC parameters at closed loop gains greater than 3.
The HA-2529 offers 150V/μs slew rate and fast settling time
(200ns), while consuming a mere 6mA of quiescent current,
making this amplifier ideal for video circuitry and data
acquisition designs. With 20MHz gain bandwidth combined
with 7.5kV/V open loop gain, the HA-2529 is an ideal
component for demanding signal conditioning designs. This
device provides ±30mA output current drive with an output
voltage swing of ±10V making it suited for pulse amplifier
and RF amplifier components.
The HA-2529 will upgrade output current, slew rate, offset
voltage drift and offset current drift in systems presently
using the HA-2520/22/25 or EHA-2520/22/25.
评论(0)
发评论
下载排行榜
