EL6196 pdf datasheet (Laser Di
消耗积分:3 | 格式:rar | 大小:543 | 2009-01-16
分享资料个
The EL6196 is a highly integrated
laser diode driver designed to support
multi-standard writable optical drives.
It accomplishes this by incorporating a waveform generator
wherein the diode currents and timing details can be
programmed before operation. The data input circuitry
inspects the NRZ serial data waveform and generates
programmed waveforms in recognition of 3, 4, 5, or 6 or
more clock periods of space changing to 3, 4, 5, or 6 or more
clock periods of mark, and vice versa. The part also has an
IV amplifier with concurrent read and write sampling. The
gains of the IV amplifier are programmable, eliminating the
need for external potentiometers.
评论(0)
发评论
下载排行榜
