用单片机设计的电话机参考源码资料下载
消耗积分:3 | 格式:pdf | 大小:79.18KB | 2021-04-15
分享资料个
  #include #include #include #include "LCD1602.h" #include "matrix_key.h" #define uint unsigned int #define uchar unsigned char #define Nop() _nop_()     sbit P10 = P1^0;  /*按键端口*/ sbit P11 = P1^1;  /*按键端口*/ sbit P12 = P1^2;  /*按键端口*/ sbit P13 = P1^3;  /*按键端口*/ bit shift_flag; bit call_flag ; bit CallIn_flag=0; bit reci_flag; bit reci_flag1; sbit sled_en_port = P3^6; /*定义数码管数据锁存器控制端口*/ sbit led_en_port = P2^5; /*定义发光二极管数据锁存器控制端口*/ sbit ds1302_en_port = P2^2; /*定义时钟的选片脚*/   ucharCallIn_Num[15];//={"00000000000"}; uchar CallOut_Num[15]={"               "}; uchar m=0;     //拨号指针 uchar temp='?'; uchar code clr[16]={"                "}; uchar code lcd_table[16]  = {"Ky: Cm:   Re:  "}; //uchar send_buff[15]; uchar reci_buff[15]={"               "}; uchar z; //接收缓冲区指针 uchar time;//定时器中断次数 uchar codemun_to_char[]={"0123456789ABCDEF"}; /*1MS为单位的延时程序*/   void init();
评论(0)
发评论
下载排行榜
