EL6206 pdf datasheet (Laser Dr
消耗积分:5 | 格式:rar | 大小:455 | 2009-01-16
张涛
分享资料个
The EL6206 is a push-pull oscillator
used to reduce laser noise. It uses the
standard interface to existing ROM
controllers. The frequency and amplitude are each set with a
separate resistor connected to ground. The tiny package and
harmonic reduction allow the part to be placed close to a
laser with low RF emissions. An auto turn-off feature allows it
to easily be used on combo CD-RW plus DVD-ROM pickups.
One external resistor sets the oscillator frequency. Another
external resistor sets the oscillator amplitude. If the APC
current is reduced such that the average laser voltage drops
to less than 1.1V, the output and oscillator are disabled,
reducing power consumption to a minimum.
The current drawn by the oscillator consists of a small bias
current, plus the peak output amplitude in the positive cycle.
In the negative cycle the oscillator subtracts peak output
amplitude from the laser APC current.
This part is pin-compatible to the EL6201. It is superior to the
EL6201 in several ways: It has up to 100mA output
capability, it is faster (up to 600MHz), it is more powerefficient,
it has less harmonic content, and it has an auto
shut-off feature activated at 1.1V.
评论(0)
发评论
下载排行榜
