ISL88731/ISL88731A pdf datashe
消耗积分:10 | 格式:rar | 大小:433 | 2009-01-18
分享资料个
The ISL88731A is a highly integrated Lithium-ion battery
charger controller, programmable over the SMBus system
management bus (SMBus). The ISL88731A is intended to be
used in a smart battery charger (SBC) within a smart battery
system (SBS) that throttles the charge power such that the
current from the AC-adapter is automatically limited. High
efficiency is achieved with a DC/DC synchronous-rectifier
buck converter, equipped with diode emulation for enhanced
light load efficiency and system bus boosting prevention. The
ISL88731A charges one to four Lithium-ion series cells, and
delivers up to 8A charge current. Integrated MOSFET
drivers and bootstrap diode result in fewer components and
smaller implementation area. Low offset current-sense
amplifiers provide high accuracy with 10mΩ sense resistors.
The ISL88731A provides 0.5% end-of-charge battery
voltage accuracy.
The ISL88731A provides a digital output that indicates the
presence of the AC-adapter as well as an analog output
which indicates the adapter current within 4% accuracy.
The ISL88731A is available in a small 5mmx5mm 28 Ld thin
(0.8mm) QFN package. An evaluation kit is available to
reduce design time. The ISL88731A is available in Pb-Free
packages.
评论(0)
发评论
下载排行榜
