KAD5610/KAD5610P pdf datasheet
消耗积分:3 | 格式:rar | 大小:433 | 2009-01-19
刘伟
分享资料个
The KAD5610P is a family of low-power, high-performance,
dual-channel 10-bit, analog-to-digital converters. Designed
with Intersil’s proprietary FemtoCharge™ technology on a
standard CMOS process, the family supports sampling rates
of up to 250MSPS. The KAD5610P-25 is the fastest member
of this pin-compatible family, which also features sample
rates of 210MSPS (KAD5610P-21), 170MSPS
(KAD5610P-17) and 125MSPS (KAD5610P-12).
A serial peripheral interface (SPI) port allows for extensive
configurability, as well as fine control of gain, skew and offset
matching between the two converter cores.
Digital output data is presented in selectable LVDS or CMOS
formats. The KAD5610P is available in a 72-contact QFN
package with an exposed paddle. Performance is specified
over the full industrial temperature range (-40°C to +85°C).
评论(0)
发评论
下载排行榜
