TC4421/TC4422 pdf datasheet (9
消耗积分:3 | 格式:rar | 大小:333 | 2009-01-19
英雄孤寂
分享资料个
The TC4421/TC4422 are high-current buffer/drivers
capable of driving large MOSFETs and IGBTs.
These devices are essentially immune to any form of
upset, except direct overvoltage or over-dissipation.
They cannot be latched under any conditions within
their power and voltage ratings. These parts are not
subject to damage or improper operation when up to
5V of ground bounce is present on their ground terminals.
They can accept, without damage or logic upset,
more than 1A inductive current of either polarity being
forced back into their outputs. In addition, all terminals
are fully protected against up to 4 kV of electrostatic
discharge.
The TC4421/TC4422 inputs may be driven directly
from either TTL or CMOS (3V to 18V). In addition,
300 mV of hysteresis is built into the input, providing
noise immunity and allowing the device to be driven
from slowly rising or falling waveforms.
With both surface-mount and pin-through-hole
packages and four operating temperature range offerings,
the TC4421/22 family of 9A MOSFET drivers fit
into most any application where high gate/line
capacitance drive is required.
评论(0)
发评论
下载排行榜
