ISL6719 pdf datasheet (100V Li
消耗积分:2 | 格式:rar | 大小:433 | 2009-02-07
好名字
分享资料个
The ISL6719 is a low cost linear regulator for generating a low voltage bias supply from intermediate distributed voltages commonly used in telecom and datacom applications. It provides a single adjustable output rated at 100mA from either the input source or an auxiliary source such as a transformer winding. The auxiliary source is selected whenever it has sufficient voltage to sustain the output.
The ISL6719 may be used as a start-up or a continuous low
power regulator. When operating as a start-up regulator, it is
capable of sourcing 100mA from a 100V source for short
durations. This period of time allows the power supply to start-up and provide an alternate power source, such as the output of a transformer winding, to the AUXIN input. This allows the regulated output to operate from a lower source voltage to minimize power loss.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
