ISL6265 pdf datasheet (Multi-O
消耗积分:10 | 格式:rar | 大小:144 | 2009-02-07
无人岛
分享资料个
Multi-Output Controller with Integrated MOSFET Drivers for AMD SVI Capable
Mobile CPUs
The ISL6265 is a multi-output controller with embedded gate
drivers. A single-phase controller powers the Northbridge
(VDDNB) portion of the CPU. The two remaining controller
channels can be configured for two-phase or individual
single-phase outputs. For uniplane CPU applications, the
ISL6265 is configured as a two-phase buck converter. This
allows the controller to interleave channels to effectively
double the output voltage ripple frequency and thereby
reduce output voltage ripple amplitude with fewer
components, lower component cost, reduced power
dissipation, and smaller area. For dual-plane processors, the
ISL6265 can be configured as independent single-phase
controllers powering VDD0 and VDD1.
The heart of the ISL6265 is the patented R3 Technology™,
Intersil’s Robust Ripple Regulator modulator. Compared with
the traditional buck regulator, the R3 Technology™ has a
faster transient response. This is due to the R3 modulator
commanding variable switching frequency during a load transient.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
