ISL6443/ISL6443A pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2009-02-07
分享资料个
300kHz Dual, 180° Out-of-Phase, Step-Down PWM and Single Linear Controller
The ISL6443A is a high-performance, triple-output controller
optimized for converting wall adapter, battery or network
intermediate bus DC input supplies into the system supply
voltages required for a wide variety of applications. Each
output is adjustable down to 0.8V. The two PWMs are
synchronized at 180° out-of-phase, thus reducing the RMS
input current and ripple voltage.
The ISL6443A incorporates several protection features. An
adjustable overcurrent protection circuit monitors the output
current by sensing the voltage drop across the lower
MOSFET. Hiccup mode overcurrent operation protects the
DC/DC components from damage during output
overload/short circuit conditions. Each PWM has an
independent logic-level shutdown input (SD1 and SD2).
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
