MAX668, MAX669 pdf datasheet
消耗积分:10 | 格式:rar | 大小:333 | 2009-02-07
分享资料个
The MAX668/MAX669 constant-frequency, pulse-width modulating (PWM), current-mode DC-DC controllers are designed for a wide range of DC-DC conversion applications including step-up, SEPIC, flyback, and isolated-output configurations. Power levels of 20W or more can be controlled with conversion efficiencies of over 90%. The 1.8V to 28V input voltage range supports a wide range of battery and AC-powered inputs. An advanced BiCMOS design features low operating current (220µA), adjustable operating frequency (100kHz to 500kHz), soft-start, and a SYNC input allowing the MAX668/MAX669 oscillator to be locked to an external clock.
DC-DC conversion efficiency is optimized with a low 100mV current-sense voltage as well as with Maxim's proprietary Idle Mode™ control scheme. The controller operates in PWM mode at medium and heavy loads for lowest noise and optimum efficiency, then pulses only as needed (with reduced inductor current) to reduce oper-ating current and maximize efficiency under light loads. A logic-level shutdown input is also included, reducing supply current to 3.5µA.
The MAX669, optimized for low input voltages with a guaranteed start-up voltage of 1.8V, requires boot-strapped operation (IC powered from boosted output). It supports output voltages up to 28V. The MAX668 operates with inputs as low as 3V and can be connected in either a bootstrapped or non-bootstrapped (IC powered from input supply or other source) configuration. When not bootstrapped, it has no restriction on output voltage. Both ICs are available in an extremely compact 10-pin µMAX® package.
评论(2)
发评论
ivan0621 2016-03-03
0 回复 举报
正好需要的资料,感谢分享! 收起回复
Zzpeng 2011-04-01
8 回复 举报
你好,我下载的时候,总是说页面不存在。可不可以请你发max668的datasheet给我?
email:yylzzp@163.com
谢谢了!
还有,请问,那里能购买到这块芯片?
管理员回复: 现在解决了
收起回复
下载排行榜
全部2条评论
