空压站控制的应用实践
消耗积分:5 | 格式:rar | 大小:333 | 2009-03-14
申换换
分享资料个
根据实际情况,分析了空压站现有运行状况,介绍了喘振的产生原因及克服方法。由此,确定了补充、完善数据检测及增加设备监测与故障诊断系统方案。实践证明,此方案具有数据采集及实时保护、在线监测预报、信号分析、故障诊断、记录等功能,为系
统的检测维修提供了一定的依据。
关键词:空压站喘振检测故障
Abstract; In accordance with the practical situations, current operating status of air compression stations are analyzed. The causes of the occurrence
of surge and the countermeasures are introduced. Thus the system strategy for supplementing comprehensive data detection and adding
equipmentsu pervisiona ndf aultd iagnosisis d etermined.In p ractice,th es ystemp rovidedth efu nctionsof da taa cquisitiona ndre altim ep rotection,
online predictive supervisory, signal analysis, fault diagnosis and data record, etc. These are the fundamental criteria for detection and
m ain tenance
Keywords:of the system.Airc ompressions tation Surge Detection Fau
评论(0)
发评论
下载排行榜
