PC/104Plus PC Card adapters an
消耗积分:3 | 格式:rar | 大小:333 | 2009-03-16
贾虎世
分享资料个
PC/104Plus PC Card adapters and WLAN cards
This list covers all standard variations of the PC/104+ modules including:
Pro versions with StackThrough PC/104+ (PCI) connector and StackThrough PC104 (ISA) connector.
LC versions with StackThrough PC/104+ connector with no PC/104 connector.
One or two antenna connectors in WIB200 series and two or four antenna connectors in WIB400 series.
Our production lines are very versatile and therefore a number of custom versions are available on request:
In addition to standard Female SMA antenna connectors SMB and RSMA (Reverse SMA) connectors .
can also be used.
Alternative antenna connector orientations are upwards and sideways.
The StackThrough PC/104+ connectors can be replaced by two versions of Non-StackThrough PC/104+
connectors depending on which side of the motherboard the module is installed.
The jumper row can be replaced by fixed connections
Overall special coating is also possible for e.g. avionics and military applications.
Conformal coating is standard in T2 versions.
The total weight of the modules depends on options used. For instance the Extended Temperature Range
and Industrial Temperature Range versions are filled with special compound and are therefore heavier than
standard versions. Detailed weight information will be in the data sheets.
All evaluation kits are delivered with two antenna connectors including one antenna cable (1 m)and one antenna.
评论(0)
发评论
下载排行榜
