SWAlertController2
参照系统的“UIAlertController”的样式UI和接口做成的弹框;
- 支持多种z外观UI的自定义;
- UI外形和系统弹框的样式统一;
- 创建、使用的接口和系统弹框的“UIAlertController”接口基本一致;
- 相对于系统弹框,除了显示文本message,还支持更多的控件类型;
- 按照“SWAlertControllerItemProtocol”控件协议,用户可以j自己创建更多的控件;
源码(Source Code)
https://github.com/shede333/SWAlertController2
https://gitee.com/shede333/SWAlertController2
示例工程(Example)
To run the example project, clone the repo, and run pod install from the Example directory first.
运行“Example”里的demo工程,需要先在根目录执行 pod install ;
安装(Installation)
SWAlertController is available through CocoaPods. To install it, simply add the following line to your Podfile:
pod 'SWAlertController2'
使用方式(Use)
使用方式,和系统的UIAlertController类似,具体详见Example目录里的Demo工程;
截图(Screenshot)
作者(Author)
shede333, 333wshw@163.com
License
SWAlertController2 is available under the MIT license. See the LICENSE file for more info.
