PCB图如下:
成分
| C16 C16 10uF CAP TANT 10UF 35V 10% 径向钽 4 Kemet | × 1 |
| C2,C4,C6,C8,C10 C2,4,6,8,10 0.22uF CAP CER 0.22UF 50V 10% 径向 X7R 15 Kemet | × 5 |
| C1,C3,C5,C7,C9,C13,C15 C1,3,5,7,9,13,15 0.1uF / 100nF CAP CER 0.1UF 50V 20% RADIAL X7R 17 Kemet | × 7 |
| C14 C14 47uF CAP TANT 47UF 6.3V 10% 径向钽 2 Kemet | × 1 |
| C18 C18 0.33uF 电容 CER 0.33UF 50V 10% 径向 X7R 2 | × 1 |
| C19 C19 0.01uF CAP CER 10000PF 50V 10% 径向 X7R 3 Kemet | × 1 |
| C11,C12,C20 C11,20 1uF 电容 CER 1UF 50V 20% 径向 X7R 4 | × 3 |
| C23 C23 4.7nF 电容 CER 4700PF 100V 10% 径向 X7R Kemet | × 1 |
| D16 D16 1N5919BG 齐纳二极管 ZENER 5.6V 3W AXIAL DO-41 1 ON Semiconductor | × 1 |
| D15,D17 D15,17 1N5818-TP 肖特基二极管 SCHOTTKY 1A 30V DO41 DO-41 18 Micro Commercial Co | × 2 |
| LED1,LED2,LED3,LED4,LED5,LED6,LED7,LED8 LED1,2,5,6 LED-红色 LED SS 3MM 625NM RED DIFF 5mm-LED | × 8 |
| D9,D10,D11,D12 D9,10 1N4004 DIODE GEN PURPOSE 400V 1A DO41 DO-41 13 Micro Commercial Co | × 4 |
| U2 U2 Surge Protection SURGE ABSORBER 14MM 22V 1000A ZNR Disc 14mm 1 Panasonic - ECG | × 1 |
| J3 螺丝接线端子 双接线端子 TERMINAL BLOCK 5MM VERT 2POS PCB On Shore Technology Inc | × 1 |
| 公针跳线 公针跳线 Jumper SHUNT JUMPER .1" BLACK GOLD | × 5 |
| 公针 公针 40 POS 0.100 排针 CONN HEADER .100" SNGL STR 40POS 1 Sullins 连接器解决方案 | × 4 |
| J4 J4 矩形连接器 - 接头,公插针 IDC BOX HEADER .100" 40POS 1 CNC Tech | × 1 |
| Q1,Q2,Q3,Q4,Q5,Q6,Q7,Q8 Q1,2,5,6,7,8 62A MOSFET N-CH MOSFET N-CH 33V 62A TO-220 TO-220 8 STMicroelectronics | × 8 |
| R39,R40,R54 R39, 40,54 10k RES 10.0K OHM 1/4W 1% METAL FILM 7 Yageo | × 3 |
| R10,R13,R16,R19,R23,R24,R29,R30,R50,R51,R57,R58,R59,R60 R10,13,23,24,50,51,57,58,59,60 1k RES 1.00K OHM 1/4W 1% 金属膜 32 国巨 | × 14 |
| R9,R12,R15,R18,R26,R28,R33,R34 R9,12,26,28 680 RES 680 OHM 0.6W 1% AXIAL TE Connectivity | × 8 |
| R2,R4,R6,R8,R22,R41 R2,4,6,8,22,41 470 RES METAL FILM 1/4W 470 OHM 1% AXIAL 9 Stackpole Electronics Inc | × 6 |
| R1,R3 R1,3 1% 2.49k 2.49k Ohm ±1% 0.25W, 1/4W 通孔电阻 GM Sensors 轴向金属膜 3 Yageo | × 2 |
| R7 R7 0.1% 3.9k RES 3.9K OHM 1/4W 0.1% 金属膜 AXL 1 国巨 | × 1 |
| R21 R21 0.1% 1.0k RES 1K OHM 1/4W 0.1% 金属膜 AXL 1 国巨 | × 1 |
| R11,R14,R17,R20,R35,R36,R37,R38,R48,R49,R55,R56 R11,14,35,37,48,49,55,56 100k RES 100K OHM 1/4W 1% 金属膜 17国巨 | × 12 |
| R25,R27,R31,R32 R25,27 160 RES 160 OHM 2W 1% AXIAL 4 Yageo | × 4 |
| U1 U1 LM2940T-5.0/NOPB IC 稳压器 LDO LM2940-5.0 1A TO220 TO-220 2 Texas Instruments | × 1 |
| MPX4250A MPX4250A 1-Bar MAP 传感器 SENSOR ABS PRESS 36.3 PSI MAX 6-SIP 1 | × 1 |
| IC1,IC2 IC1 TC4424EPA IC MOSFET DVR 3A DUAL HS 8-DIP 8-DIP 2 | × 2 |
| IC4 IC4 SP721APP TVS 阵列 ESD 6 输入 30V 8-DIP 8-DIP 1 | × 1 |
| IC SOCKET MACH PIN ST 8POS TIN IC SOCKET MACH PIN ST 8POS TIN IC 插座 | × 3 |
| 案例案例 1 Hammand Manufacturing 1455N1202 | × 1 |
| Arduino 超级 Arduino 超级 | × 1 |
Hyduino 4.2 (Speeduino+ H2 Gms (气体管理系统)
