PCB图如下:
成分
| C1,C15 0.01uF 电容_SMD:C_0805_2012公制国巨CC0805KRX7R9BB103 2 | × 2 |
| C17 10uF 电容器_钽_SMD:CP_EIA-7343-31_Kemet-D Kemet T491D106K050AT | × 1 |
| C19 22uF 电容_SMD:C_0805_2012Metric_Pad1.15x1.40mm_HandSolder Samsung CL21A226KQCLRNC | × 1 |
| C21 47uF 电容器_钽_SMD:CP_EIA-3528-21_Kemet-B AVX TAJB476K006RNJ | × 1 |
| C24,C26,C3,C9,C10,C11,C4,C16,C18,C20,C23,C22 0.1uF电容_SMD:C_0805_2012公制国巨CC0805KRX7R9BB104 | × 12 |
| C25,C27,C2 1uF电容_SMD:C_0805_2012公制国巨CC0805KKX7R7BB105 | × 3 |
| C6,C12,C13,C14,C7,C5 0.22uF电容_SMD:C_0805_2012公制三星CL21B224KOCNNNC | × 6 |
| C8 470pf 电容器_SMD:C_0805_2012公制国巨CC0805KRX7R9BB471 | × 1 |
| D12,D11,D5,D6,D18,D17,D19,D16 D 二极管_SMD:D_SOD-323 MCC 1N4448WX-TP | × 8 |
| D13,D20 D_Zener Diode_SMD:D_SOD-323 On Semi MM3Z5V1ST1G | × 2 |
| D14 B130-13-F Diode_SMD:D_SMA Diodes,Inc B130-13-F | × 1 |
| D15 1SMB5919BT3G 二极管_SMD:D_SMB On Semi 1SMB5919BT3G | × 1 |
| D4,D3,D8,D7,D1,D2,D9,D10 LED LED_SMD:LED_0805_2012Metric Osram LH,R974-LP-1 | × 8 |
| F1,F2 Polyfuse Fuse:Fuse_1812_4532Metric Bel,Fuse 0ZCC0050FF2C | × 2 |
| JP1 Ignition,Voltage Connector_PinHeader_2.54mm:PinHeader_1x03_P2.54mm_Vertical Harwin,Inc M20-9990345 | × 1 |
| JP2,JP3 VR-HALL 连接器_PinHeader_2.54mm:PinHeader_1x03_P2.54mm_Vertical Harwin,Inc M20-9990345 | × 2 |
| JP5,JP4 上拉连接器_PinHeader_2.54mm:PinHeader_1x02_P2.54mm_Vertical Harwin,Inc M20-9990245, | × 2 |
| Q1、Q3、Q2 SSM3K357R 封装_TO_SOT_SMD:SOT-23 东芝 SSM3K357R | × 3 |
| R1,R2,R15,R16,R3,R4,R19,R20,R50,R49,R61,R60 100k电阻器_SMD:R_0805_2012公制国巨RC0805FR-07100KL | × 12 |
| R10,R9,R24,R23,R11,R12,R25,R26,R33 2.4k电阻器_SMD:R_0805_2012公制国巨RC0805FR-072K4L | × 9 |
| R13,R14,R27,R28 10R电阻器_SMD:R_0805_2012公制国巨RC0805FR-0710RL | × 4 |
| R30 3.9k电阻器_SMD:R_0805_2012公制国巨RC0805FR-073K9L | × 1 |
| R34,R31,R38,R39,R40,R32,R63,R62 470R电阻器_SMD:R_0805_2012公制松下ERJ-6ENF4700V | × 8 |
| R35,R36 2.49k 电阻器_SMD:R_0805_2012公制国巨 RT0805BRD072K49L | × 2 |
| R43,R44 220R电阻器_SMD:R_0805_2012公制国巨RC0805FR-07220RL | × 2 |
| R45,R51 10k 电阻器_SMD:R_0805_2012Metric Yageo RC0805JR-0710KL | × 2 |
| R46 120R电阻器_SMD:R_0805_2012公制国巨RC0805FR-07120RL | × 1 |
| R5,R6,R17,R18,R7,R8,R21,R22,R29,R37,R41,R42,R47,R48,R56,R57,R53 1k电阻器_SMD:R_0805_2012公制国巨RC0805FR-071KL | × 17 |
| R52 2k 电阻器_SMD:R_0805_2012Metric Yageo RC0805FR-072KL | × 1 |
| RV1 压敏电阻 压敏电阻:RV_Disc_D15.5mm_W4.7mm_P7.5mm Bournes,Inc MOV-14D220K | × 1 |
| S1 AYZ0202AGRLC 杂项:AYZ0202AGRLC C,&,K,组件 AYZ0202AGRLC | × 1 |
| U1,U3,U7,U9 VNLD5090 封装_SO:SOIC-8_3.9x4.9mm_P1.27mm STMicro VNLD5090-E | × 4 |
| U2,U4 TC4424A 封装_SO:SOIC-8_3.9x4.9mm_P1.27mm Microchip TC4424AVOA | × 2 |
| U5 MPX4250 杂项:MPX4250 NXP MPX4250AP | × 1 |
| U6 SP720 封装_SO:SOIC-16_3.9x9.9mm_P1.27mm Littelfuse SP720ABTG | × 1 |
| U8 LM2940S-5.0/NOPB 封装_TO_SOT_SMD:TO-263-3_TabPin2 TI LM2940S-5.0/NOPB | × 1 |
Hyduino 4.4b (Speeduino+ H2 Gms (气体管理系统)
