PCB图如下:
成分
| C16 10uF CAP TANT 10UF 35V 10% 径向钽 Kemet T356G106K035AT 399-3654-ND 80-T356G106K035AT | × 1 |
| C2,C4,C6,C8,C10,C24 0.22uF CAP CER 0.22UF 50V 10% 径向 X7R Kemet K224K20X7RF5UH5 BC2678CT-ND 594-K224K20X7RF5UH5 | × 6 |
| C1,C3,C5,C7,C9,C13,C15 0.1uF / 100nF CAP CER 0.1UF 50V 20% 径向 X7R Vishay K104K15X7RF53H5 BC3323-ND 80-C322C104M5R-TR | × 6 |
| C14 47uF CAP TANT 47UF 6.3V 10% 径向钽 Kemet T356F476K006AT 399-3652-ND 80-T356F476K6AT | × 1 |
| C18 0.33uF CAP CER 0.33UF 50V 10% 径向 X7R AVX Corporation AR215F334K4R 478-5120-ND 581-AR215F334K4R | × 1 |
| C19,C25 0.01uF CAP CER 10000PF 50V 10% 径向 X7R Kemet C317C103K5R5TA 399-4206-ND 80-C317C103K5R | × 2 |
| C11、C12、C20 1uF 电容 CER 1UF 50V 20% 径向 X7R Kemet C330C105M5U5TA 399-4390-ND 80-C330C105M5U | × 3 |
| C23 4.7nF 电容 CER 4700PF 100V 10% 径向 X7R Kemet C317C472K1R5TA 399-4243-ND 80-C317C472K1R | × 1 |
| D16 1N5919BG 齐纳二极管 ZENER 5.6V 3W 轴向 DO-41 ON Semiconductor 1N5919BG 1N5919BGOS-ND 863-1N5919BRLG | × 1 |
| D15,D17 1N5818-TP 肖特基二极管 SCHOTTKY 1A 30V DO41 DO-41 Micro Commercial Co 1N5818-TP 1N5818-TPCT-ND 833-1N5818-TP | × 2 |
| LED1,LED2,LED3,LED4,LED5,LED6,LED7,LED8 LED-红色 LED SS 3MM 625NM RED DIFF 5mm-LED LTL-4221N 160-1139-ND 859-LTL-4221N | × 6 |
| D9,D10,D11,D12 1N4004 DIODE GEN PURPOSE 400V 1A DO41 DO-41 Micro Commercial Co 1N4004-TP 1N4004-TPMSCT-ND 833-1N4004-TP | × 4 |
| U2 Surge Protection SURGE ABSORBER 14MM 22V 1000A ZNR Disc 14mm Panasonic - ECG ERZ-V14D220 P7307-ND 667-ERZ-V14D220 | × 1 |
| J3 双接线端子 TERMINAL BLOCK 5MM VERT 2POS PCB On Shore Technology Inc OSTTA020161 ED2561-ND 571-2828362 | × 1 |
| 公针跳线 Jumper SHUNT JUMPER .1" BLACK GOLD 969102-0000-DA 3M9580-ND 517-9691020000DA | × 5 |
| 公针 40 POS 0.100 排针 CONN HEADER .100" SNGL STR 40POS Sullins 连接器解决方案 PREC040SAAN-RC.. S1012EC-40-ND 571-41037410 | × 4 |
| J4 矩形连接器 - 接头,公插针 IDC BOX HEADER .100" 40POS CNC Tech 3020-40-0100-00 1175-1614-ND 571-5103308-8 | × 1 |
| Q1,Q2,Q3,Q4,Q5,Q6,Q7,Q8 62A MOSFET N-CH MOSFET N-CH 33V TO-220 TO-220 STMicroelectronics STP75NS04Z 497-5981-5-ND 511-STP62NS04Z | × 8 |
| 10k RES 10.0K OHM 1/4W 1% 金属膜 Yageo MFR-25FBF52-10K 10.0KXBK-ND 71-RN60D-F-10K | × 1 |
| R10,R13,R16,R19,R21,R23,R24,R29,R30,R39,R40,R50,R51,R57,R58,R59,R60 1k RES 1.00K OHM 1/4W 1% METAL FILM Yageo MFR-25FBF52- 1K 1.00KXBK-ND 71-RN60D-F-1.0K | × 17 |
| R9,R12,R15,R18 680 RES 680 OHM 0.6W 1% 轴向 TE Connectivity 1622545-1 A105963CT-ND 279-LR1F680R | × 4 |
| R2,R4,R6,R8,R22,R41 470 RES 金属薄膜 1/4W 470 OHM 1% AXIAL Stackpole Electronics Inc RNF14FTD470R RNF14FTD470RCT-ND 279-LR1F470R | × 6 |
| R1,R3,R26,R28,R33,R34,R61 1% 2.49k 2.49k Ohm ±1% 0.25W, 1/4W 通孔电阻轴向金属膜 适用于GM Sensors Yageo MFR-25FBF52-2K49 2.49KXBK-ND 603- MFR-25FBF52-2K49 | × 7 |
| R7 0.1% 3.9k RES 3.9K OHM 1/4W 0.1% 金属膜 AXL 国巨 MFP-25BRD52-3K9 3.9KADCT-ND 279-H83K9BDA | × 1 |
| R11,R14,R17,R20,R35,R36,R37,R38,R48,R49,R55,R56 100k RES 100K OHM 1/4W 1% 金属膜 Yageo MFR-25FBF52-100K 100KXBK-ND 603-FMF-25FTF52100K | × 12 |
| R25,R27,R31,R32 160 RES 160 OHM 2W 1% 轴向 Yageo FMP200FRF52-160R 160YCT-ND 594-5083NW160R0J | × 4 |
| U1 LM2940T-5.0/NOPB IC 稳压器 LDO LM2940-5.0 1A TO220 TO-220 Texas Instruments LM2940T-5.0/NOPB LM2940T-5.0/NOPB 926-LM2940T-5.0/NOPB | × 1 |
| MPX4250A 1-Bar MAP 传感器 SENSOR ABS PRESS 36.3 PSI MAX 6-SIP Freescale Semiconductor MPX4250AP MPX4250AP-ND 841-MPX4250AP | × 1 |
| IC1,IC2 TC4424EPA IC MOSFET DVR 3A DUAL HS 8-DIP 8-DIP Microchip Technology TC4424EPA TC4424EPA-ND 579-TC4424EPA | × 2 |
| IC4 SP721APP TVS 阵列 ESD 6 输入 30V 8-DIP 8-DIP Littelfuse Inc. SP721APP F2720-ND 576-SP721APP | × 1 |
| IC SOCKET MACH PIN ST 8POS TIN IC Socket AR08-HZL-TT-R AE10011-ND 571-1-2199298-2 | × 3 |
| Case Hammand Manufacturing 1455N1202 HM975-ND 546-1455N1202 | × 1 |
| Arduino Mega 1050-1018-ND | × 1 |
Hyduino 4.3b (Speeduino+ H2 Gms (气体管理系统)
