LFPAK封装MOSFET的散热设计指南
消耗积分:0 | 格式:pdf | 大小:158 KB | 2011-04-02
liuxin
分享资料个
Power MOSFETs are commonplace in modern electronic circuit design, where they are
frequently used to switch loads of many different types – ranging from a few milliamps or
less to several tens of amps, depending on application. The popularity of power
MOSFETs is almost certainly attributable to their ease of drive compared to their bipolar
counterparts, together with the wide range of package, voltage and RDS(on) combinations
which are now available.
Of course, MOSFETs are not perfect switches and neither are they indestructible, and the
circuit designer should be aware of the following thermal considerations when designing a
system employing MOSFET devices
评论(0)
发评论
下载排行榜
