基于Arduino系统的GARDUINO
消耗积分:0 | 格式:zip | 大小:0.08 MB | 2022-11-23
刘玉兰
分享资料个
1 / 8DHT11 温度和湿度数据以及自动刷新的土壤传感器数据的实时数据
加杜诺
GARDUINO是一个基于Arduino的系统,用于监控我们工厂的温度、湿度、土壤湿度和光照状态,并自动提供其必要的需求,如光、水和纯新鲜空气,甚至一些传感器用于控制一些致动器。
植物浇水由土壤湿度传感器控制,该传感器用于在需要时打开水泵。
温度/湿度传感器负责打开和关闭12V直流冷却风扇和灯。
水马达、灯和风扇可以使用谷歌助手或Garduino网站远程控制。
使用土壤传感器,可以使用Garduino网站实时监测温度和湿度值。
对于外部数据分析,运行名为datavisualize的python脚本。py,它将运行一个无限脚本并将传感器数据上传到一个txt文件中,该文件可以在MATLAB中进一步使用。
FLOW Diagram
HARDWARE
ARDUINO UNO: It is the micro controller board that is equipped with sets of digital and analog input/output pins and has a USB connection to load programs from personal computers.
SOIL-MOISTURE SENSOR: It measures the volumetric water content indirectly in the soil by using soil properties like electrical resistance etc.
TEMPERATURE-HUMIDITY SENSOR (DHT11): The DHT11 is a basic, ultra low-cost digital temperature and humidity sensor.
LED LIGHT & 12V DC COOLING FAN: These are triggered together by the DHT11 temperature-humidity sensor when the surrounding temperature drop down below a plant-healthy level.
RELAY: It is an electrically operated switch which is used where it is necessary to control a circuit by a low-power signal or where several circuit must be controlled by one signal.
DC 12V WATER PUMP SUBMERSIBLE: This is triggered by the soil-moisture sensor as and when the soil gets dry and watering of the plants is needed.
SOFTWARE SPECIFICATIONS:
The project is developed using JSON, REST, PHP, JS, HTML, CSS, Arduino, MYSQL, cloud services and webhooks (IFTTT).
CONCLUSION
The system will reduce the human efforts in gardening and also make the gardening automated and tech friendly. It also makes the appropriate use of resources like water and electricity which will reduce the wastage of these resources and will also improve the health and life of plants.
NOTE
This project uses many different tools whose detailed explanation would be not possible, so if your are not able to figure out anything, feel free to ping me.
This file is part of GARDUINO. GARDUINO is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or(at your option) any later version. GARDUINO is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with GARDUINO. If not, see <http://www.gnu.org/licenses/>.
评论(0)
发评论
下载排行榜
