项目 #11:ESP32 Feather - PIR 运动传感器 - Mk11
PIR 运动传感器
被动红外 (PIR) 传感器是全球安全系统中使用的运动检测设备,即使您可能看不到它们,它们也可能会看到您。
这是一个简单易用的运动传感器。打开电源并等待 1-2 秒,让传感器获取静止房间的快照。如果在那段时间之后有任何变化,“警报”引脚将变低。
Pololu 可调升压稳压器 2.5-9.5V
This powerful, adjustable boost regulator can generate an output voltage as high as 9.5 V from an input voltage as low as 1.5 V, all in a compact, 0.42" x 0.88" x 0.23" package. A trimmer potentiometer lets you set the boost regulator’s output voltage to a value between 2.5 and 9.5 V.
DL1911Mk02
1 x Adafruit HUZZAH32 ESP32 Feather
1 x Adafruit SHARP Memory Display
1 x Adafruit Adalogger FeatherWing - RTC + SD
1 x CR1220 12mm Lithium Battery
1 x 8Gb Micro SD Card
1 x RHT03 Humidity and Temperature Sensor
1 x GPS Receiver GP-20U
1 x LED Green
1 x Rocker Switches
1 x 100 Ohm
1 x 10K Ohm
1 x 3.3M Ohm
1 x Antenna
1 x Lithium Ion Battery - 2.5Ah
1 x PIR Motion Sensor
1 x Pololu Adjustable Boost Regulator 2.5-9.5V
1 x LED Green 1
14 x Jumper Wires 3" M/M
10 x Jumper Wires 6" M/M
2 x Wire
1 x Full-Size Breadboard
2 x Breadboard
1 x SparkFun Cerberus USB Cable
LG0 - Digital 21
RO1 - Digital 16
RHT - Digital 17
SCK - Digital 13
MOS - Digital 12
SSD - Digital 27
SDA - Digital 23
SCL - Digital 22
SD1 - Digital 33
SC2 - Digital 5
MO2 - Digital 18
MI2 - Digital 19
GPS - Digital 4
EMF - Analog A0
BAT - Analog A13
MOT - Digital 32
LG1 - Digital 14
GND - GND
VIN - +3.3V
