PCB天线设计指南(英文资料)
消耗积分:0 | 格式:rar | 大小:345 KB | 2011-05-11
zaojinguo
分享资料个
Taking the demand for small size, easy fabrication and low cost into account in the
development of low-power radio devices for short-range 2.4GHz applications, a
quarter wavelength monopole antenna implemented on the same printed circuit board
as the radio module is a good solution. A printed quarter wavelength monopole
antenna is very easy to design and can be tuned simply by slight changes in length.
This article presents basic guidelines on how to design such an antenna for use
together with the nRF2401 Single chip Transceiver and the nRF2402 Single chip
2.4GHz Transmitter.
The described antenna should be fabricated on standard 1.6mm, low cost FR4 printed
circuit board (PCB).
评论(0)
发评论
下载排行榜
