C5xx / 80C5xx In-System FLASH
消耗积分:3 | 格式:rar | 大小:333 | 2009-04-01
生龙活虎3
分享资料个
In-System FLASH Programming with hardware
implemented bank switching capability
The following information concerns all microcontrollers of the C5xx / SAB 80C5xx family
which use an internal ROM mask in combination with an external code FLASH memory.
The external FLASH memory can be used as reprogrammable code memory for the
application software. This application focuses on SIEMENS 8-bit microcontroller
derivatives with internal code memory (ROM) sizes of 8/16 Kbyte in maximum because
of the overlapped code memory area of the FLASH memory of 8/16 Kbyte cannot be
used:
·  C501-1R
·  C502-2R
·  C504-2R
·  C511(A)-R
·  C513(A)-R/-2R
·  C515-1R
·  SAB 80C535
·  SAB 80C537
This application note describes the proceeding for the in-system reprogramming of
application software by using special application hardware for memory bank switching and
software programming service routines in the internal mask programmable ROM for
external FLASH memories (5V-only).
评论(0)
发评论
下载排行榜
