B340LA/B340LB,pdf (3.0A LOW VF SCHOTTKY BARRIER RECTIFIER)
消耗积分:0 | 格式:rar | 大小:322 KB | 2011-05-18
dplion
分享资料个
Features
•Very Low Forward Voltage Drop
•Guard Ring Die Construction for Transient Protection
•Ideally Suited for Automated Assembly
•Low Power Loss, High Efficiency
•Surge Overload Rating to 70A Peak
•Lead Free Finish/RoHS Compliant (Note 3)
Mechanical Data
•Case: SMA/SMB
•Case Material: Molded Plastic. UL Flammability Classification Rating 94V-0
•Moisture Sensitivity: Level 1 per J-STD-020D
•Terminals: Lead Free Plating (Matte Tin Finish). Solderable per MIL-STD-202, Method 208
•Polarity: Cathode Band or Cathode Notch
•Marking Information: See Page 3
•Ordering Information: See Page 3
•Weight: SMA 0.064 grams (approximate)
SMB 0.093 grams (approximate)
评论(0)
发评论
下载排行榜
