The C500 microcontroller family usually provides only one on-chip synchronous serial channel (SSC). If a second SSC is required, an emulation of the missing interface may help to avoid an external hardware solution with additional electronic components. The solution presented in this paper and in the attached source files emulates the most important SSC functions by using optimized SW routines with a performance up to 25 KBaud in Slave Mode with half duplex transmission and an overhead less than 60% at SAB C513 with 12 MHz. Due to the implementation in C this performance is not the limit of the chip. A pure implementation in assembler will result in a strong reduction of the CPU load and therefore increase the maximum speed of the interface. In addition, microcontrollers like the SAB C505 will speed up the interface by a factor of two because of an optimized architecture compared with the SAB C513. Moreover, this solution lays stress on using as few on-chip hardware resources as possible. A more excessive consumption of those resources will result in a higher maximum speed of the emulated interface. Due to the restricted performance of an 8 bit microcontroller a pin compatible solution is provided only; the internal register based programming interface is replaced by a set of subroutine calls. The attached source files also contain a test shell, which demonstrates how to exchange information between an on-chip HW-SSC and the emulated SW-SSC via 5 external wires in different operation modes. It is based on the SAB C513 (Siemens 8 bit microcontroller). A table with load measurements is presented to give an indication for the fraction of CPU performance required by software for emulating the SSC.
