The MAX11626–MAX11629/MAX11632/MAX11633 areserial 12-bit analog-to-digital converters (ADCs) with annternal reference. These devices feature on-chip FIFO,scan mode, internal clock mode, internal averaging,and AutoShutdown™. The maximum sampling rate is300ksps using an external clock. The MAX11632/MAX11633 have 16 input channels; the MAX11628/MAX11629 have 8 input channels; and the MAX11626/MAX11627 have 4 input channels. These six devicesoperate from either a +3V supply or a +5V supply, andcontain a 10MHz SPI™-/QSPI™-/MICROWIRE™-compatibleserial port.
