Abstract: This application note describes the MAX1464 signal conditioner's sensor compensation algorithm. This algorithm will compensate and calibrate a sensor signal applied to one of the MAX1464's ADC channels, thus providing offset and span correction over temperature. The discussion assumes that the supply voltage to the MAX1464 does not change during the compensation process.
