分布式并行服务器中的高性能通信研究
消耗积分:3 | 格式:rar | 大小:228 | 2009-04-26
分享资料个
基于快速以太局网中分布式并行服务器通信特点和对网络协议栈的分析,设计并实现了一种分布式操作系统传输协议。该协议在维持通用编程接口的同时,精简网络协议栈底层的冗余操作,减少操作系统干预和协议自维护开销。在8个节点的服务器系统上的测试结果表明,分布式操作系统传输协议获得比用户数据报协议更小的往返延迟和系统开销,应用环境下有约20%的增益,能有力地支持系统扩展和大并发访问服务。Aiming at the characteristics of the LAN of fast Ethernet and distributed parallel server system, a novel distributed operating system transport protocol (DOSTP) is proposed in this paper. The goal of this work is to study how to reduce the communication software overheads in the distributed parallel server system with off-shelf equipments, moreover to keep the common programming interfaces. Several measurements, such as decreasing redundant operations at underlying protocol stack, reducing OS interventions and the overheads of protocol self-maintenance, are used to improve the performance. Experiments have been done on the server of 8 PIII PC nodes and 100Mbps Ethernet with switches. Compared with UDP/IP, DOSTP decreases round-trip time of 20% for 64 bytes packets under the same application conditions.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
