MICROSOFT FOUNDATION CLASS LIBRARY : SimpleDrawDlg
AppWizard has created this SimpleDrawDlg application for you. This application
not only demonstrates the basics of using the Microsoft Foundation classes
but is also a starting point for writing your application.
This file contains a summary of what you will find in each of the files that
make up your SimpleDrawDlg application.
SimpleDrawDlg.dsp
This file (the project file) contains information at the project level and
is used to build a single project or subproject. Other users can share the
project (.dsp) file, but they should export the makefiles locally.
SimpleDrawDlg.h
This is the main header file for the application. It includes other
project specific headers (including Resource.h) and declares the
CSimpleDrawDlgApp application class.
SimpleDrawDlg.cpp
This is the main application source file that contains the application
class CSimpleDrawDlgApp.
SimpleDrawDlg.rc
This is a listing of all of the Microsoft Windows resources that the
program uses. It includes the icons, bitmaps, and cursors that are stored
in the RES subdirectory. This file can be directly edited in Microsoft
Visual C++.
SimpleDrawDlg.clw
This file contains information used by ClassWizard to edit existing
classes or add new classes. ClassWizard also uses this file to store
information needed to create and edit message maps and dialog data
maps and to create prototype member functions.
res\SimpleDrawDlg.ico
This is an icon file, which is used as the application's icon. This
icon is included by the main resource file SimpleDrawDlg.rc.
res\SimpleDrawDlg.rc2
This file contains resources that are not edited by Microsoft
Visual C++. You should place all resources not editable by
the resource editor in this file.
