71M6543F,71M6543G,71M6543GH,71M6543H电表IC
消耗积分:1 | 格式:pdf | 大小:2.01 MB | 2012-02-21
分享资料个
 The 71M6543F, 71M6543H, 71M6543G, and 71M6543GH are Teridian’s 4th-generation polyphase metering systems-on-chips (SoCs) with a 5MHz 8051-compatible MPU core, low-power real-time clock (RTC) with digital temperature compensation, flash memory, and LCD driver. Our Single Converter Technology® with a 22-bit delta-sigma ADC, seven analog inputs, digital metrology temperature compensation, precision voltage reference, and a 32-bit computation engine (CE) supports a wide range of metering applications with very few external components.
评论(0)
发评论
下载排行榜
