The DS1921H/Z Thermochron iButtons are rugged, self-sufficient systems that measure temperature andrecord the result in a protected memory section. The recording is done at a user-defined rate, both as a direct storage of temperature values as well as in the form of a histogram. Up to 2048 temperature valuestaken at equidistant intervals ranging from 1 to 255 minutes can be stored.
