CD4016.pdf
消耗积分:10 | 格式:rar | 大小:133 | 2008-04-02
385288
分享资料个
The CD4016BC is a quad bilateral switch intended for the
transmission or multiplexing of analog or digital signals. It is
pin-for-pin compatible with CD4066BC.
Features
 Wide supply voltage range: 3V to 15V
 Wide range of digital and analog switching: ±7.5 VPEAK
 “ON” Resistance for 15V operation: 400Ω (typ)
 Matched “ON” Resistance over 15V signal input:
ΔRON = 10Ω (typ)
 High degree of linearity:
0.4% distortion (typ)
@ fIS = 1 kHz, VIS = 5 Vp-p,
VDD−VSS = 10V, RL = 10 kΩ
 Extremely low “OFF” switch leakage:
0.1 nA (typ.)
@ VDD − VSS = 10V
TA = 25°C
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
