基于电力线载波通讯的工业照明管理系统
消耗积分:5 | 格式:rar | 大小:214 | 2009-05-27
h1654155957.9921
分享资料个
本文描述了一种利用电力线载波通讯来实现的工业照明用电管理系统。该系统利用现
有交流电源线作为通讯线路,不用铺线,具有投资少、与电网建设同步等优势。主机通过电力线载波通讯将对路灯的管理命令发送到终端,终端执行相应的开关操作,然后将相应的状态信息返回到主机。电力载波部分基于PL3105 核心芯片实现。
关键字:电力线; 工业照明; 管理系统
Management System for the Industrial Illumination based on the Power Line Communication
HU Hongbo (Zunyi Normal College, Guizhou Zunyi 563002) Abstract: This paper describes a monitoring system of the lighting usage of power plant. This system uses the power line as the communication carrier, which has the advantages such as no need for communication wiring, low cost and easy construction (can be built when the power grid is constructed), etc.. The host sends command to the terminal through powerline carrier to control the lighting at the field, and the terminal commits corresponding operation, returns corresponding state information to the host. The power line communication is implemented on the PL3105 chip.
Keywords: Power Line; Industrial Illumination; Management System
下载资料需要登录,并消耗一定积分。
评论(1)
发评论
1591789880 2022-04-20
0 回复 举报
青岛嘉讯通智能科技有限公司--专注于电力载波通信设备研发技术支持:15564870569,刘工 收起回复
下载排行榜
全部1条评论
