一种结合分形编码的图像检索算法
消耗积分:5 | 格式:rar | 大小:162 | 2009-05-30
贾飞世
分享资料个
为了更有效、更准确地进行的图像检索,在迭代函数系统收敛速度理论和拼贴定理的基础上,提出了一种结合分形编码进行基于内容的图像检索方法,即把查询图像的分形码应用于图像库中的图像进行分形迭代,然后将得到的图像与查询图像进行相似匹配,在检索正确率和检索速度方面,优于实验中其他方法。实验证明了该算法的有效性和可行性。
关键词:分形编码;迭代函数系统;基于内容的图像检索
A New Method of Texture-Based Image Retrieval Combining Fractal Coding Zhang Hong-xia Ma Yan Shi Shu-jian (Department of Computer, Shanghai Normal University, china, 200234) 【Abstract】Based on the theory of the speed of convergence for iterative function system and Collage theorem, a new approach of content-based image retrieval combining fractal coding is proposed to retrieve images effectively in this paper. The fractal codes of the query image is applied and iterated on the images in the database. The iterated image is matched with the query image. The proposed method is better than other methods in accuracy and speed. The experiments show that the proposed method is effective and feasible.
【Key words】 Fractal Coding; Iterative Function System; Content-based Image Retrieval
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
