L6569和L6561在照明方面的应用(该应用电路带功率因数
消耗积分:10 | 格式:rar | 大小:28 | 2009-05-30
赵辉
分享资料个
The application has been developed to supply two 18W fluorescent lamps. It consists of two sections: a Power Factor Corrected preregulator (PFC), using the L6561, and the lamp ballast stage with the L6569 (see fig.1).
The power factor corrector section is based on the L6561. This is an IC intendedto control PFC preregulators by using the transition mode technique. It is especially dedicated for electronic lamp ballast applications (to better understand the L6561 characteristics refer to AN966).
评论(0)
发评论
下载排行榜
