The 71M6541DT/71M6541FT/71M6542FT (71M654x)are 4th-generation single-phase metering systems-onchips(SoCs) with a 5MHz, 8051-compatible MPU core,low-power RTC with digital temperature compensation,flash memory, and LCD driver. Our Single ConverterTechnology® with a 22-bit delta-sigma ADC, three or fouranalog inputs, digital temperature compensation, precisionvoltage reference, and a 32-bit computation engine(CE) support a wide range of metering applications withvery few external components.
