W6630 特性说明和在VCD系统方面的应用电路介绍
消耗积分:3 | 格式:rar | 大小:52 | 2009-06-11
分享资料个
The Winbond W6630 is a stereo audio DAC chip incorporating 8X digital interpolatioin filters, 64X multi-level oversampling delta-sigma modulators, analog low-pass filter and output amplifiers. The operation voltage for this chip can be from 2.7 volt to 5.25 volt. Moreover, the 16 or 18 Bit linear input data for DAC consists of two formats, normal format and I2S format. In addition, the device includes two control modes. One is hardware mode which can control mute and digital de-emphasis. The other one is software mode, where 4x9 bits internal control registers can be controlled by the serial setup port (SSP). Many functions such as 256 step attenuation, DAC mute, digital de-emphasis and format conversions can be setup through these registers.
评论(0)
发评论
下载排行榜
