SDR SDRAM Controller (White Pa
消耗积分:10 | 格式:rar | 大小:23 | 2009-06-14
分享资料个
SDR SDRAM Controller August 2002, ver. 1.1 1
M-WP-SDR-1.1 Introduction
The single data rate (SDR) synchronous dynamic random access memory (SDRAM) controller provides a simplified interface to industry standard SDR SDRAM. The SDR SDRAM Controller is available in either Verilog HDL or VHDL and is optimized for the Altera® APEX™ architecture. The SDR SDRAM Controller supports the following
features:
■ Burst lengths of 1, 2, 4, or 8 data words
■ CAS latency of 2 or 3 clock cycles
■ 16-bit programmable refresh counter used for automatic refresh
■ 2-chip selects for SDRAM devices
■ Supports the NOP, READA, WRITEA, AUTO_REFRESH, PRECHARGE, ACTIVATE, BURST_STOP,
and LOAD_MR commands
■ Support for full-page mode operation
■ Data mask line for write operations
■ PLL to increase system performance
■ Support for data-path widths of 16, 32, and 64 bits
Figure 1 shows a system-level diagram of the SDR SDRAM Controller.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
