一种基于序列译码的快速相关攻击算法
消耗积分:3 | 格式:rar | 大小:141 | 2009-06-17
麻酱
分享资料个
快速相关攻击是一种重要的序列密码分析方法。该文提出一种基于卷积码的序列译码的快速相关攻击算法,首先利用特殊的校验方程将线性分组码转化为低码率卷积码,然后用卷积码的序列译码算法恢复出密钥。当记忆长度较大时,该算法显著地降低了[1]中算法的译码复杂度。
关键词 相关攻击卷积码序列译码算法
Abstract Fast correlation attack is one of the important cryptanalysis method for stream
ciphers. This paper presents a new fast correlation attack algorithm which based on
error-correcting codes. First, transferring the linear block code to a convolutional code with low rate using special parity check equations; then obtaining the key from squence decoding
algorithm of convolutional code. The new algorithm notably reduces the decoding complexity of the fast correlation attack algorithm from [1].
Keywords Correlation attack Convolutional code sequence decoding algorithm
评论(0)
发评论
下载排行榜
