介绍M68HC1引导程序模式的工作和应用
消耗积分:3 | 格式:rar | 大小:267 | 2009-06-19
tr12345
分享资料个
The M68HC11 Family of MCUs (microcontroller units) has a bootstrap
mode that allows a user-defined program to be loaded into the internal
random-access memory (RAM) by way of the serial communications
interface (SCI); the M68HC11 then executes this loaded program. The
loaded program can do anything a normal user program can do as well
as anything a factory test program can do because protected control bits
are accessible in bootstrap mode. Although the bootstrap mode is a
single-chip mode of operation, expanded mode resources are
accessible because the mode control bits can be changed while
operating in the bootstrap mode.
评论(0)
发评论
下载排行榜
