MAX3301E-MAX3302E.pdf
消耗积分:3 | 格式:rar | 大小:776 | 2008-04-23
梅利号
分享资料个
The MAX3301E/MAX3302E fully integrated USB On-the-
Go (OTG) transceivers and charge pumps allow mobile
devices such as PDAs, cellular phones, and digital
cameras to interface directly with USB peripherals and
each other without the need of a host PC. Use the
MAX3301E/MAX3302E with an embedded USB host to
directly connect to peripherals such as printers or
external hard drives.
The MAX3301E/MAX3302E integrate a USB OTG trans-
ceiver, a VBUS charge pump, a linear regulator, and an
I2C-compatible, 2-wire serial interface. An internal level
shifter allows the MAX3301E/MAX3302E to interface
with +1.65V to +3.6V logic supply voltages. The
MAX3301E/MAX3302E’s OTG-compliant charge pump
operates with +3V to +4.5V input supply voltages, and
supplies an OTG-compatible output on VBUS while
sourcing more than 8mA of output current.
The MAX3301E/MAX3302E enable USB OTG communi-
cation from highly integrated digital devices that cannot
supply or tolerate the +5V VBUS levels that USB OTG
requires. The device supports USB OTG session-request
protocol (SRP) and host-negotiation protocol (HNP).
The MAX3301E/MAX3302E provide built-in ±15kV elec-
trostatic-discharge (ESD) protection for the VBUS, ID_IN,
D+, and D- terminals. The MAX3301E/MAX3302E are
available in 25-bump chip-scale (UCSP™), 25-bump
WLP package, 28-pin TQFN, and 32-pin TQFN pack-
ages and operate over the extended -40°C to +85°C
temperature range.
评论(0)
发评论
下载排行榜
