针对调节燃煤锅炉的风煤比,本文对其送风调节子系统进行优化。在实际运行经验数 据的基础上,构成了调节送风量的专家知识库,用以作为推理的基础。实际经验证明,应用本文设计的专家控制器,对锅炉燃烧控制系统中的送风调节子系统进行局部控制,在现场实际控制中可以获得较好的控制效果。 关键字:送风调节子系统 专家知识库 优化设计 Abstract: Contraposing to regulate proportion between coal and air of boiler, this paper optimize the regulated subsystem which is used to send blast. On the base of actual experience data,the expert's knowledge database which is used to regulate the amount of blast is formed,and is the foundation of consequence.If the expert's knowledgedatabase which is designed in this paper is used to control locally the regulated sending-blast subsystem of the boiler combustion-control system, the better control result will be acquired in the practice.And it has been proved from the actual experience Keyword: Sending-blast regulated subsystem Expert's knowledge database Optimization design
