针对某星载合成孔径雷达快视成像系统具有数据量大、存储量大等特点,分析了其 信号处理系统应有的功能,提出了一种使用FPGA 进行距离向降采样滤波的方法,解决了FPGA控制2GB SDRAM 存储器的技术问题,并实现了基于高性能浮点DSP 和大规模FPGA 的异构处理系统。 关键词:星载合成孔径雷达,快视成像,降采样率波,异构。 Abstract: This paper contains the satellite synthetic aperture radar signal processing with large amounts of data, large memory capacity and other characteristics, It analysised the function of the signal processing system, a method of using FPGA to reduce the ranging sampling filter, solved controlling 2 GB SDRAM memory based on FPGA, and implemented isomerous system of high-performance floating-point DSP and large scale FPGA. Key word: Spaceborne SAR, quick-look imaging, reduced sampling filter, isomerous
