系统内非易失性闪速存储器再编程的原理、软硬件注意事项及对80
消耗积分:5 | 格式:rar | 大小:616 | 2009-06-26
王飞云
分享资料个
1.0 INTRODUCTION  1
1.1 PROM Programmer vs
System-Processor Controlled
Programming  1
1.2 Information Download and
Upload  1
Version Updates (Download)  1
Data Acquisition (Upload)  1
2.0 DEVICE FEATURES AND ISW
APPLICATION
CONSIDERATIONS  2
2.1 Flash Memory Pinouts  2
2.2 Command Register
Architecture  4
Simplified Processor Interface  4
Command Register Reset  5
Data Protection on Power
Transitions  5
2.3 VPP Specifications  6
3.0 HARDWARE DESIGN FOR ISW  6
3.1 VPP Generation  6
3.1.1 Regulating Down from
Higher Voltage  6
3.1.2 Pumping 5V up to 12V  6
3.1.3 Absolute Data Protection Ð
VPP On/Off Control  7
3.1.4 Writes and Reads during
VPP Transitions  7
3.1.5 Other VPP Considerations  7
3.1.6 VPP Circuitry and Trace
Layout  8
3.2 Communications Ð Getting Data
to and from the Flash
Memory  8
CONTENTS PAGE
4.0 SOFTWARE DESIGN FOR ISW  8
4.1 System Integration Ð Boot Code
Requirements  8
4.1.1 ISW Flag Check  9
4.2 Communication Protocols and
Flash Memory ISW  9
4.3 Data Accumulation Software
Techniques  10
4.4 Reprogramming Routines  10
4.4.1 Quick-Erase Algorithm  10
Algorithm Timing Delays  10
High Performance Parallel
Device Erasure  11
4.4.2 Quick-Pulse Programming
Algorithm  12
Algorithm Timing Delays  12
Device Programming  12
4.4.3 Pulse Width Timing
Techniques  13
Software Methods and
Examples  13
Hardware Methods  13
5.0 SYSTEM DESIGN EXAMPLE: AN
80C186 DESIGN  14
6.0 SUMMARY  15
评论(0)
发评论
下载排行榜
