光电传感器的电磁兼容设计
消耗积分:5 | 格式:rar | 大小:160 | 2009-06-27
31274
分享资料个
在多个光电传感器构成的计算机控制系统中,电磁兼容是很重要的。经过电磁兼容设计,光电传感器的电磁辐射强度降低了,抗电磁干扰能力显著提高。介绍了光电传感器主要部分及整体进行电磁兼容设计的方法,提供了电磁兼容试验方法。
关键词: 光电传感器; 电磁兼容; 设计; 试验
Abstract : In computer control system of many photoelectric sensors ,electromagnetic compatibility is very impor2 tant.Because of design on electromagnetic compatibility ,electromagnetic radiation of the photoelectric sensor is reduced ,capability of anti2electromagnetic2interference is raised. Methods of design of main parts and whole sen2
sor are introduced. The method of design of electromagnetic compatibility test is introduced.
Key words : photoelectric sensor ; electromagnetic compatibility ; design ; test
评论(0)
发评论
下载排行榜
