熔铝电阻率测量系统的研制
消耗积分:3 | 格式:rar | 大小:160 | 2009-06-27
刘洋
分享资料个
熔铝电阻率的测量基于电涡流原理,设计了传感器的结构和标定方法。为了简化测量熔铝电阻率的硬件电路,在信号处理电容中采用了LVDT 专用芯片AD598 硬软件结合消除了温度影响,在熔铝及铝基合金的凝固研究中得到实用。
关键词:测量; 电阻率; 电涡流; 熔铝检测
Abstract : The measurement of molten aluminum electrical resistivity is based on the eddy current principles. In the system the structure and calibrating method of the transducer is properly designed. In order to simplify the hardware circuit ,the AD5982LVDT special chip is adopted in the signal processing circuit . By rational combine of software and hardware the temperature effect is effectively eliminated. This system has been applied to the freezing study of molten aluminum and aluminum alloy.
Key words :measurement ; electrical resistivity ; eddy current ; examination of molten aluminum
评论(0)
发评论
下载排行榜
