红外循迹小车程序
#include 《reg52.h》
#include 《intrins.h》
#define uchar unsigned char
#define uint unsigned int
#define SIGNAL P2
//L298带动两个电机M1、M2
sbit IN1 = P1^0; //M1_L
sbit IN2 = P1^1; //M1_R
sbit IN3 = P1^2; //M2_L
sbit IN4 = P1^3; //M2_R
sbit ENA = P1^6; //M1_E
sbit ENB = P1^7; //M2_E
sbit chuan1=P2^0;
EA = 1;
M1_n = 2; //0~8, 代表0/8~8/8
M2_n = 2; //0~8, 代表0/8~8/8
M1_PWM = PWM[M1_n];
M2_PWM = PWM[M2_n];
P0 = 0;
P1 = M1_PWM;
P2 = M2_PWM;
uchar check(void)
uchar temp;
temp=SIGNAL&0x0f;
return temp;
void main()
{ uchar keep;
initiate();
while(1)
keep=check();
if(keep==0x00)
M1_R=0;//代表左右转的控制的标志位写法
M2_R=0;
if(keep==0x01)
M1_R=0;
M2_L=0;
if(keep==0x10)
M1_R=0;
M2_R=0;
if(keep==0x11)
M1_R=0;
M2_L=1;
void T0_INT(void) interrupt 1
TL0 = (65536 - 500) % 256; //重新赋值
TH0 = (65536 - 500) / 256; //1ms@12MHz
