LM239集电极开路输出四电压比较器资料
Single Supply Quad Comparators These comparators are designed for use in level detection, low−level sensing and memory applications in consumer, automotive, and industrial electronic applications.
Features • Pb−Free Packages are Available* • Single or Split Supply Operation • Low Input Bias Current: 25 nA (Typ) • Low Input Offset Current: ±5.0 nA (Typ) • Low Input Offset Voltage • Input Common Mode Voltage Range to GND • Low Output Saturation Voltage: 130 mV (Typ) @ 4.0 mA • TTL and CMOS Compatible • ESD Clamps on the Inputs Increase Reliability without Affecting Device Operation
