lm393 pdf
消耗积分:10 | 格式:rar | 大小:555 | 2008-05-05
分享资料个
The LM393 series are dual independent precision voltage comparators
capable of single or split supply operation. These devices are designed to
permit a common mode range–to–ground level with single supply operation.
nput offset voltage specifications as low as 2.0 mV make this device an
excellent selection for many applications in consumer automotive, and
ndustrial electronics.
• Wide Single–Supply Range: 2.0 Vdc to 36 Vdc
• Split–Supply Range: ±1.0 Vdc to ±18 Vdc
• Very Low Current Drain Independent of Supply Voltage: 0.4 mA
• Low Input Bias Current: 25 nA
• Low Input Offset Current: 5.0 nA
• Low Input Offset Voltage: 2.0 mV (max) LM393A
5.0 mV (max) LM293/393
• Input Common Mode Range to Ground Level
• Differential Input Voltage Range Equal to Power Supply Voltage
• Output Voltage Compatible with DTL, ECL, TTL, MOS, and CMOS Logic
Levels
• ESD Clamps on the Inputs Increase the Ruggedness of the Device
without Affecting Performance
评论(3)
发评论
乐天派木木 2016-04-19
0 回复 举报
谢谢 收起回复
feng1000120304 2011-04-06
4 回复 举报
还好哦啊,谢了! 收起回复
全部评论
下载排行榜
全部3条评论
